BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Most of the times that's possible for the older mk1 version of the Ouverture. But it can be converted to a newer mechanism (used in the mk2).
The newer mk2 version of the Ouverture has most likely the VAM1255 laser and can't be replaced by a cheap ebay version.
You first need to know which laser has been placed inside the Ouverture (or 2300, the one which needs repair). For that you need to dismantle the Beosound.
