I have a Beovision 4 50" with DVI Input. I wish I would to use it only as Monitor because my Beosystem 2 is just broken. My question is how can I turn on and turn off the TV without using the Beo4.
Is someone of you found a solution about a similar issue?
Thank you
A generic Panasonic remote can do basic functions such as on/off and selecting the input. the IR sensor is behind the bezel in the lower left corner. You might need to point the remote up from below the bezel.
A second-hand BeoSystem 3 can usually be found at a good price and give you a great upgrade in picture, connections, and functionality.
