The way you describe the use of BS5 together BS3000 is correct, List N.Music then GO:The other issue. Switch off all system. Then connect power. Do not connect power to BM5.When all up and running, the connect power to BM5/BS5.If not working try option 2-1 (BS5 in option 1):When setting BS5 in option 0 or 1, make sure the option is saved properly.I have had the same issue. Audio master and option 0 was not saved properly.Further make sure that BM5/BS5 is listed correct in connection in BV7.
If the BV7 Setiting is correct, you can test using the PC command..Check in BS5 setting, that below parameters are correct:How to do is deschribes in latest version of user manua.lAs the BS5 is now Audio Master: Radio= N.Radio, CD= CD- Ripper, N.Music = A.Mem After changing from Slave to Master the N.radio and N.Music command is no longer active ascommands.Hope that this will help.
For setting up the BV7 for North America, See page US-Manual for BV7 from page 11 to page 16.PC is Beomaster5(Beosound5) AV5 to be used. Remember also to connect the Digital Output on BM5 to the Digital input on AV5:This gives better soundoutput on BV7 speakers.
For BS5 setup see English installation guide page 11 (Fully integratet Audio Master Setup).
Very very happy to hear, that all is up and running. :) :) :)
