Hello gentlemen,
I have a Beogram 1900 which was previously owned by my grand father. It has a Din male connector. I also have a Pro-next Tube Box S2 with RCA connectors (+ ground).
Actually I m using a DIN female to RCA male adapter (without ground wire and which was used with the Beogram previously) to the pre amp but I think it is not the best wiring solution. Do you have any advices about a better cable ?
should I try to remove the OEM DIN cable and to weld another RCA + ground cable ? Or just a better DIN - RCA adapter with ground ?
Florent: should I try to remove the OEM DIN cable and to weld another RCA + ground cable ? Or just a better DIN - RCA adapter with ground ?
A DIN-RCA adapter with separate ground wire would be best.
