Beolab 3500 + essence mk1
This post has 8 Replies | 2 Followers
liviu_o
Posts 157
liviu_o Posted: Thu, Aug 6 2020 6:34 AM
Hi!
I would like to use this combo for the kitchen. Is it possible? I am wondering if a powerlink conected bl3500 to essence mk1 will be able to stream music from tunein(essence) or phone.
Thank you!
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Beolab 3500 isn't really an ideal speaker for this setup, unless you also have a Beosound music system with Masterlink (or a Beolink Converter or NL/ML Converter) to drive the speaker.  Please can you let me know which other B&O products you have, so that I can assist further?
Kind regards, Steve.
Steve.
www.soundsheavenly.com
liviu_o
Posts 157
liviu_o replied on Sat, Aug 8 2020 8:24 AM
Steve at Sounds Heavenly:
Steve.
Sure, but I don’t think it may help: beovision 11-55, beosound 1, beoplay a2, essence mk1.
I am thinking of a variant for a 20m2 kitchen.
Posts 2,165
Thanks for your reply, the simple answer here is "Don't buy Beolab 3500 for this setup".  You will get much better sound and easier operation with almost any other Beolab or Beoplay speakers.  Beolab 3500 and 2000 are not a good option for this setup unless you are willing to add the B&O Converter box as a direct cable connection is not possible here.
Steve.
liviu_o
Posts 157
liviu_o replied on Sun, Aug 9 2020 8:07 AM
Thank you! Much apreciated!
liviu_o
Posts 157
liviu_o replied on Sat, Aug 22 2020 3:29 PM
Steve.
Steve,
What about a beolab 7.x in connection with Essence mk1?
Posts 2,165
Yes a Beolab 7-1 is a much better option, you can connect to the Essence with this cable:-
https://soundsheavenly.com/bang-olufsen/31-325-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html#/9-length-18m
Steve.
liviu_o
Posts 157
liviu_o replied on Sat, Aug 22 2020 8:22 PM
Steve.
It will have a single channel (mono) sound? Or it will be a stereo stream?
Posts 2,165
For Beolab 7-1, 7-2 and 7-6 this will be stereo.  Beolab 7-4 would be mono.
Kind regards Steve.
Steve.
Page 1 of 1 (9 items) | RSS
