Hi
my first post so please forgive me if i breach protocol , i have one passive in a beolink set up , i want to upgrade the external speaker , ( Kef Ventura 6) which need a bit more power than the beolink can deliver 60 vs 120 w , can you use two passives in parallel ?
Don
The passive was not designed to run in parallel.
All I can say about the rest is try it with the new speakers and see how it sounds.
Another option would be to replace the passive with a beolink active, and add your own amplifier.
