Beosystem 5000 hung in "Standby" mode.
fletch444
Posts 1
fletch444 Posted: Mon, Dec 10 2012 3:36 PM
I've tried to restart my Beosystem 5000 after sitting unused for nearly 5 years.  It is stuck in "standby" mode and it will not release when I press the dot on the front of the system or the remote control panel.
I don ot have the service manuals.  Can anyone provide some suggestions??
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Dec 10 2012 4:19 PM
The dot switches to stand by. I take it you have tried starting one of the sources either on the remote or, for instance, by pressing play on the cassette? I would guess that you will need the Beomaster servicing - there are all sorts of things it could be - usually capacitors and variable resistors out of spec.
Peter
Page 1 of 1 (2 items) | RSS
