New Eclipse
This post has 13 Replies | 1 Follower
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, Sep 2 2020 9:30 AM
Good day to you all
Well I thought I would post a new thread about the Eclipse which I got yesterday.
My thoughts are that this TV is amazing.
I will factory restore it at the weekend so I can start all settings from scratch to make sure its setup as standard and then tweak if needed.
I have reset the sound settings and some picture settings.
The BeoLab 5 and 6000’s as rears really come alive with this setup I didn’t quite realise how different it would sound.
My feeling so far was that until I reset the sound settings that there was hardly any voice, I have sorted this temporarily.
One thing I cannot work out is if you can modify the items in the list menu to move Homecontrol up to the top as its down the bottom, on the non BT remote you can change the menu items.
I have also noticed that the homecontrol menu takes much longer to open then on the avant 55
My main real concern is that moving from Avant 55 LED to Eclipse 65 is that the picture is hurting my eyes, i think because it is so bright and i have noticed its mainly when there is sunshine scenes on the program as the white is sooo bright, I hope I can resolve this by factory restore and starting again.
A question I have if anyone knows if you can connect a SKY satellite into the SAT input on the TV to give freesat as the Apps on the TV don’t work like the Apple TV giving live TV and I suppose I should add an Ariel.
also if the SAT dish connection will give UHD signal.
Sean
Anyway
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Fansastic
The Hague, The Netherlands
Posts 768
You cannot change the menu in the BR1. The OLED is so bright, I’ve the contrast to 75, any higher it hurts my eyes Big Smile
Regarding external SAT / TV inputs I cannot help you, I use the CI+ module in the TV.
Enjoy the Eclipse, it is a great TV
Emil Jensen
Denmark
Posts 766
I always put it in ISF dark (Or something similar dont remember right now if that is what it is called on the Eclipse)
When you put it in these modes, the picture is much more correct,
And it will be much better for your eyes.
It can seem dim compared to the standard setting, but the standard setting is really far from correct picture.
Seanie_230
UK
Posts 2,278
Hello all
I can confirm if you connect a SKY dish freesat works lovely and you can filter the guide by HD channels which is nice.
As for the picture I am getting used to it after a few days but I am indeed changing the setting when i feel its too bright, I tried ECO picture rather than smart picture option and it helps a bit also.
Thanks again
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
This weekend is the cable tide task to hide everything to create a nice install.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Aussie Michael
Melbourne, AU
Posts 3,730
Seanie_230:
Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
Excellent :-)
kuyttendaele
Posts 707
The Eclipse in combination with the BL5s.... pure envy! But I hope you enjoy it a lot!!
Karel.
Seanie_230
UK
Posts 2,278
kuyttendaele:
Karel.
Thank you very much
Made some progress at lunch
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Curly
FL, USA
Posts 366
Curly replied on Fri, Sep 4 2020 1:24 PM
It appears you self-installed. Alone? How’d that process go?
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Seanie_230
UK
Posts 2,278
Hello there
I didn’t install the TV that was mainly done by Matt and Lee from eBay after many many questions on my part.
They turned up, removed avant and moment and installed the TV.
Some of my cables were too short so I might need a new one or two which i will workout this weekend.
So they did the main install and heavy lifting and I am doing the tide up.
I do however have the YouTube video of how to install an Eclipse from scratch but to be honest didn’t fancy it when I don’t have too lol.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Done Big SmileBig SmileBig Smile
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Better with a Saturday beer before F1 qualifier
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
RS4346
Posts 15
RS4346 replied on Sat, Sep 5 2020 12:45 PM
Seanie You did a good job. Everything nicely concealed. That's how I like to see it.
The Beonic Man
Bristol
Posts 812
Yes its a lovely setup Seanie. Congrats and enjoy :)
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Page 1 of 1 (14 items) | RSS
