How to connect BS4 and BL6000 with BV10 with Multilink?. Help please!
This post has 8 Replies | 0 Followers
Veermer
Murcia, Spain
Posts 49
Veermer Posted: Fri, Sep 4 2020 4:06 PM
Hello, I have a problem, which I cannot solve, and I hope you can help me.
What do I have? A Bv10, and a BS4 with a pair of BL6000s connected with Powerlink to the Beosound 4 A Bv10, and a BS4 with a pair of BL6000s connected with Powerlink to the Beosound 4
What do I want to achieve? use the BL6000 together with the Beovision 10's own speakers for an audio system like the one below.
What did I do? I connected the BV and BS with a masterlink cable, and selected Option1 in both cases, as the instructions indicate.
What is the problem? I can't make it work as a single device: the volume of the speakers connected to the BS4 is independent of that of the speakers of the BV10, and the two overlap producing echo.
My question is, can I get a configuration with the BL6000s connected to the BS4 working as front speakers and the Bv10 speakers as central? What I have to do? what am I doing wrong?
Thank you very much.
Beovision 10-46, Beocenter 1, Beo 4, Beocom 4, Beolit 12, Beosound 4, Beosound Essence, Beolab 6000
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Sep 4 2020 5:01 PM
Hello,
just connect your Beosund4 beolab 6000 speakers to the Beovision 10.
Now set the V.Opt to 2 and A.Opt to 0
the Beosound 4 will be controlled via the TV Infrared sensor over the masterlink cable Smile
In the sound setup menu of the TV set the front left and front right speakers to beolab 6000.
Now you can listen to audio sources and video sources.
The mentioned V.Opt =1 setting is used if only the TV is used. If Audio and TV are connected via masterlink, as you want it, the VOpt=2 and AOpt=0 setting is necessary.
Ralph-Marcus
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Sep 4 2020 5:03 PM
the second pait of BL 6000 can be used as rear speakers for the TV. Gives a nice Dolby Surround system. Wink
Ralph-Marcus
Veermer
Murcia, Spain
Posts 49
Veermer replied on Fri, Sep 4 2020 6:36 PM
Thanks for your answer. But, is that setup to use when the speakers are connected to the BV? In my case they are connected to the BS. I have in that way because all the connection cables (apple tv, bluray, etc) of the BV are inside the wall, and the powerlinks do not fit inside the tube with the rest of the cables.
Millemissen
Flensborg, Denmark
Posts 14,680
Veermer:
I’d agree with Ralph-Marcus.
Don’t let that problem keep you away from making a decent/better setup.
Once done, you’ll enjoy your BV the more.
(PL cables are thin and should be easy to hide).
Veermer
Murcia, Spain
Posts 49
Veermer replied on Sat, Sep 5 2020 9:23 PM
Thanks for the advice. If it is definitely impossible to do it otherwise, I will try to do it as you say, and connect the BL directly to the BV.
Veermer
Murcia, Spain
Posts 49
Veermer replied on Fri, Sep 11 2020 4:29 PM
Finally I connected the BL6000 directly to the BV10, and this with Masterlink to the BS4, as recommended in the previous posts. And my user experience is very good. I can now really enjoy multiple audio and video sources at the push of a button, listening to them through the BV10's center speakers and the BL6000's side speakers. I can have TV, DTV, Blueray and HDD movies (through a Dune), Apple TV and Chromecast, and now Radio fm, CD music, SD card music, and online music (with the Essence connected to Aux.In) like spotify, etc.
I think it's quite impressive, for an almost vintage equipment, and partly "low cost" (Essence, BS and BL were bought already used and quite cheap). Despite their age, they work well, handle very well and everything fits perfectly.
In relation to B&O we usually talk a lot about price and cost, but in my opinion we tend to forget to talk about value.
 Thanks again for the help.
Razlaw
Posts 4,345
Razlaw replied on Fri, Sep 11 2020 5:19 PM
Glad to hear it is working!
Millemissen
Flensborg, Denmark
Posts 14,680
Great to hear that you’ve found your solution.
Didn’t I tell you....there are always options for a better setup, even with ‘older’ B&O stuff.
Page 1 of 1 (9 items) | RSS
