More Beocenter 3300 issues
This post has 5 Replies | 2 Followers
DanCharman
Posts 6
DanCharman Posted: Wed, Feb 20 2019 1:44 PM
Hi All,
I have just noticed that my beocenter 3300 has a low buzz that only occurs when the phono button is depressed? What is puzzling me further is that it doesn’t start straight away but after about 8 seconds and builds up from nothing to a significant buzz?
it sounds like a ground loop but as it only occurs on the phone setting and isn’t constant I was thinking it may be something else? Any thoughts and help would be greatly appreciated?
Many thanks,
Dan
sportdoc
Posts 5
I have the same issue with my Beocenter 3300. A low hummmm, only in phono. Sounds like an open phono ground. But it isn't that. Turntable is grounded.
Wonder what to check next?
sportdoc
Posts 5
sportdoc replied on Fri, Sep 11 2020 1:30 PM
Anybody have any clue as to what to check to try to diagnose and solve this issue???
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Sep 11 2020 2:16 PM
Cartridge mounted?
sportdoc
Posts 5
sportdoc replied on Fri, Sep 11 2020 4:18 PM
Yes.
Thank you.
The turntable plays on other receivers perfectly, and that's how we know that there is an issue with the Receiver; not the TT.
Dillen
Posts 13,191
Dillen replied on Fri, Sep 11 2020 4:29 PM
Capacitors in the power supply module fresh?
Page 1 of 1 (6 items) | RSS
