RJ45 PUC A to 3.5mm female mono jack wiring - anything special?
ebnrob
UK
Posts 174
ebnrob Posted: Tue, Sep 22 2020 3:11 PM
Hi all, I'm about to purchase a b&o to Atlona IR opto-coupler (part #8780312) for IR PUC control at my Atlona matrix - it will connect the beovision 11 PUC out to the Atlona AT-PRO3HDREC receiver box IR input. The opto-coupler end for the TV is 3.5mm mono male jack, so I need to convert this to the BV11's PUC RJ45. B&O sell a ready made cable for this job which is part #6271233, but I'm thinking I can wire this one up myself so long as there's no circuitry in between?
I'm thinking the positive of the 3.5mm mono socket connects to RJ45 pin 5 and negative to Pin 6? Anyone know for sure?
Many thanks,
Rob.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Sep 23 2020 9:20 AM
There's a Dutch thread here with BV11 RJ45 pinout diagrams: https://archivedforum2.beoworld.org/forums/p/20907/171790.aspx#171790
Your thinking appears to be right!
Page 1 of 1 (2 items) | RSS
