Hi all,
When we upgraded from a BV11 to the Eclipse at the start of the year we decided to drop our Sky subscription and move over to using the Apple TV (integrated neatly into the back), along with NowTV and using Freeview via the satellite dish. This has been working well but having dropped Sky we’ve started to miss the ability to pause live TV, etc.
Has anyone used a USB HDD integrated into the back of the Eclipse for pausing/recording live TV that they can recommend? Checking the online (LG) guide on the B&O website doesn’t give much info other than it should be an HDD with at least 80Gb of storage. We’re aiming to have one small enough to fit into the TV connection panel so it’s hidden away...
Any experience or suggestions would be appreciated,
Many thanks,
Matt
Matt:Hi all, When we upgraded from a BV11 to the Eclipse at the start of the year we decided to drop our Sky subscription and move over to using the Apple TV (integrated neatly into the back), along with NowTV and using Freeview via the satellite dish. This has been working well but having dropped Sky we’ve started to miss the ability to pause live TV, etc. Has anyone used a USB HDD integrated into the back of the Eclipse for pausing/recording live TV that they can recommend? Checking the online (LG) guide on the B&O website doesn’t give much info other than it should be an HDD with at least 80Gb of storage. We’re aiming to have one small enough to fit into the TV connection panel so it’s hidden away... Any experience or suggestions would be appreciated, Many thanks, Matt
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Hi Dyssegaard,
Thank you so much for the reply, that’s just what I was looking for. I’ve ordered one tonight, and will post an update once I have it installed. Out of curiosity, did you have to format the drive before use?
Matt:Hi Dyssegaard, Thank you so much for the reply, that’s just what I was looking for. I’ve ordered one tonight, and will post an update once I have it installed. Out of curiosity, did you have to format the drive before use? Many thanks, Matt
Appreciate the quick reply! The drive is arriving this evening, so will format it to NTFS and give it a go.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael:Does not exfat work? Big file compatibility and read-write on both Mac and pc. Ntfs is primarily for Windows only use. Beolab 50, Beolab 20, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9i, BeoPlay H6, EarSet 3i, BeoVision Avant 55, BeoPlay V1-40, BeoCom 6000 and so much else :)
Just to follow up with this thread, after formatting the drive to NTFS and connecting it to the USB 3.0 port on the TV it works a treat!
Dyssegaard - Thanks once again for information, it’s really appreciated.
