Beoremote One
frog
Camberley UK
Posts 624
frog Posted: Sun, Jan 3 2021 4:08 PM
im Just refurbishing a Beoremote One satin which was quite bashed, so I hammered the edge dents out, and sanded it so it looks OK, the only issue is that it appears that the satin remote is actually painted. I wonder if anyone knows the RAL number of the paint so I can get the remote back to perfect?
tobeyone
Posts 125
I thought the remote was anodised not painted........
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 4 2021 9:36 AM
The one I have is certainly not painted.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Jan 4 2021 5:33 PM
Hiort:
maybe he means, the one!
Beolink 1000
frog
Camberley UK
Posts 624
frog replied on Mon, Jan 4 2021 5:57 PM
No.... Beoremote one. There is a coating on the satin one. Maybe he has a gloss one.
Mikipidia
Posts 2,169
No way that’s painted...
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 4 2021 9:03 PM
Carolpa:
Hiort:
Beolink 1000
NopeBig Smile
Beoremote One and my satin remote is not painted or lacquered.
frog
Camberley UK
Posts 624
frog replied on Tue, Jan 5 2021 12:27 PM
YupBig Smile
Here you can see the interior of the remote - plus on fixing the (major) dents in the edge of the remote, how the covering - whether paint or anodizing is removed.
Anyhow, I guess that nobody knows the RAL number, so I'll match it optically.
Yup Big Smile
Mikipidia
Posts 2,169
Mikipidia replied on Tue, Jan 5 2021 12:45 PM
I don't believe there is a ral number, iirc they are bead blasted and then anodised clear.
Page 1 of 1 (9 items) | RSS
