Hi Good day here in Houston! this will be my first thread in this forum. I am drawn into your community as I own B&O speakers and since then I have fallen in love how they sound.
On the otherhand,I have a vintage beovox s40 that needs refoaming. I have been searching in the net but most suppliers are outside US. Are there any compatible replacement foam that I can use and buy? I would appreciate any links. thank you
Thanks Rich! I appreciate it. :-)
Looks like I used Simply Speakers last time.
It's been so long since I've tried to insert a hyperlink on this site, I've forgotten how to do it! Shame on me!
https://www.simplyspeakers.com/bang-olufsen-speaker-repair-foam-edge-kits.html
Great! I will let you know how this project will came out. I just ordered now with simplyspeakers.com. :-) Thank you!
I have finally replaced the foam of my beovox S40. It was an easy thing following instructions from simply speakers brochure. Thank you Rich! How I wish I can post the pre and post pic here but i could not find a way in embedding the photos here. Im still looking forward now to test the sound of the speakers.
