Hello,
My BV 10-46 has recently developed a problem with the DVB module, and occasionally when using the Apple TV 3rd generation. The main issue is that the picture freezes, and the top left and bottom right corners turns into black(ish). This happens after a few seconds when using the DVB-module, and occasionally also when using the Atv.
https://www.bang-olufsen.com/en/story/bangolufsen-collectiveis this a known issue?
My real question is wether the TV is a write off or if it could be a known issue that is repairable.
I would be very happy for any responses.
Regards
Sverre
