Hi all,
I have inherited a couple of Beolab 8000 speakers. Any suggestion on how I should connect them to my Grundig TV? Now I am using a standard audio cable from "line out" to the red and white input sockets in the TV. That works OK, but it´s quite a bit of noise. Are there any hubs or adapters that I could try;
Powelink cables ---> Adapter ---> TV (using optical, hdmi ARC, etc.)
