BEOCENTER 2002
Julimart
Posts 7
Julimart Posted: Mon, Oct 5 2020 11:35 PM
Dear All,
I have inherit the above complete with a pair of Beovox S45 on stands. The foam surrounds have failed although  I have the kits to re foam both. Beocenter 2002 has two problems; 1. The belt to the cassette deck has failed -  should be easy to fix 2. The turntable has a nasty wobble - any ideas how to over come this. Or should I just be satisfied with my CDX, Beocenter 2100 & Beogram 6000 with MMC 20EN cartridge? The Beocenter is fitted with a MMC 20S cartridge.
Julian
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 6 2020 6:30 AM
1. Belts for Beocenter 2000/2002 tape and turntable here:
https://www.beoparts-shop.com/product-category/beocenter/beocenter-2002/
2. Wobble? Is the platter or subplatter distorted, moving up and down? Or is the rotational speed uneven (belt slipping)?
Julimart
Posts 7
Thank you for the link to the spares shop.
The whole unit has been stored  covered in a dry garage for a number of years with the transit screws turned down to prevent  the whole deck from bouncing around. Having now given the 2002 a thorough clean it does look stunning. With regard to the turntable, when I tried to play a record the deck vibrated so violently that I had to prevent the tone arm from bouncing across the record. It would appear to do this at both 33 & 45 rpm.
I did run the turntable without the plater - the belt does not seem to move.
I hope my description is of some use.
Is there a damping system that requires greasing?
Regards,
Julian
Page 1 of 1 (3 items) | RSS
