EgonOlsen:Hi Beoworlders, Since yesterday i have a beosound core at home. It replaces my 7 years old playmaker. Playmaker was a good solution for me. But there is no TuneIn and no multiroom. Greetings from Germany
Moin,
I suppose that you mean.....’there is no multiroom’, when trying to use TuneIn!
Did you set up a (free!) account on TuneIn?
And did you add these credentials to the Core/setup page?
What puzzles me is, that you already have an A9....so I’d assume that the app would already know your settings, if you set up the Core with the same B&O account???
Not a solution from here - just something to consider.
TuneIn definitely works on a Core! MM
Ok - aber dann hatte ich deine Posting falsch gelesen.
Es hörte sich - für mich wenigstens - so an, als ob du dich gewundet hast, daß im Core kein TuneIn vorhanden sei!
Ich verstehe jetzt, daß du gemeint hast,daß das mit dem Playmaker nicht der Fall war.
Also - alles bestens!
Viel Spass mir dem Core :-)
EgonOlsen:Hi Beoworlders, Since yesterday i have a beosound core at home. It replaces my 7 years old playmaker. Playmaker was a good solution for me. But there is no TuneIn and no multiroom. My bs core is via aux on my beosound 9000 mk2. On the beosound core line in is also my rega record vinyl player. On bs 9000 are my beolab 18. everything works fine. But an very cool extra for me is, now i can take my vinyl sound to another room with my beoplay a9 mk2 over multiroom. Very cool. I am very happy. Greetings from Germany
Skide godt Egon!
I’d say, no, not really.
The only way I could think of, is to use the Essence Remote in one of the mixed ir and bt modes.
See the comment from petrobeli at the end of this theead:
https://archivedforum2.beoworld.org/forums/t/17876.aspx
‘Those new modes allow the Essence Remote to work at the same time with IR and Bluetooth.
They are used in the case you have plugged an Essence Box to the line-in/AUX of an older BeoSound/BeoMaster product. Those new modes would send AUX & volume commands (to the old BeoSound/BeoMaster) via IR, but at the same time prev/next/change source will go to the Essence Box via Bluetooth.’
Thus sending the ir command to the Aux and volume control of the 9000 and the command for source changing to the Core.
Not much humour from the German side... oh well.....
Brian: Not much humour from the German side... oh well.....
Brian:Not much humour from the German side... oh well.....
