I have just moved into a new home and the Beoplay V1 was part of the trip. It was perfectly packed in a wooden box during the trip.
Problem : I just switched it on, it was working normally. But after a couple minute smoke was going off the TV cabinet (left side when you watch the screen).
It was a black smoke of burned plastic.
I immediately unplugged it and now I have no idea of what to do ?
Mat
OK.... I can see that there is a rubber layer that is unscrewed...
How can I open the cabinet ?
Thank you, there are 6 screws behind the removable cable cover. I have tried removing them but nothing move and I do not want to pull hard as I am unsure.
Thank you. Yes there are 6 screws behind the cable cover at the back. I have tried removing them but nothing moves... I do not want to force as I am unsure. If someone know where to pull it would help me a lot.
Hello the stand has been removed and the 6 screw behind.
I just don't know where to pull to open the TV.
Pat: Check the ice amp as they like to burn sometimes - between the speakers.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I managed to open the tv.
Screw at the back + removing the 4 screw at the angle + pull out the tube at the bottom
Then it opens like a clam shell.
As I wasn't sure I will send it for service tomorrow.
I took it to the service center. 500 EUR ... for a new power supply.
matbkk:I took it to the service center. 500 EUR ... for a new power supply.
