Beomaster 1000 + Beogram 4004 Pin question
Writeleandro
Posts 2
Writeleandro Posted: Tue, Nov 17 2020 4:59 AM
Hi all, I've enjoyed my Beomaster 1000 for a few years and today bought a Beogram 4004 tt to go with it...only to find out the tt has a 7 pin connector and the beomaster a 5 pin input. Is there an adapter that would solve that problem? Ty
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Nov 17 2020 8:32 AM
On most (but not all) Beograms and Beocords with a 7-pin DIN plug at the signal cable, the two outer pins (6 & 7) can be unscrewed from the plug using a very small (watchmakers) screwdriver.
Keep the pins in a safe place - you will need them when you replace your Beomaster 1000 with a Beomaster 2400-2 and want to remote control the Beogram.
Writeleandro
Posts 2
Thank you! It worked!!
Page 1 of 1 (3 items) | RSS
