BeoCenter 7700 - Dust Cover - light bulb 12V
analog_tommy
Posts 1
analog_tommy Posted: Mon, Feb 19 2018 5:01 PM
Hello,
I am a happy user of a rebuilt BeoCenter 7700 with refurbished S55 speakers :)
Recently though, the little light bulb in the dust cover has died and finding a replacement is difficult as I only know the voltage and size.
I've combed the forum threads  and internet for answers but without success. The service manual does not mention more than that it is a 12v bulb.
The owner manual mentions product number 8230088, whereas the service manual uses 8230077.
Does anyone know the wattage of the bulb?
cheers,
Tomek
Homersaurus
Posts 28
It's a bit late for a reply, but if you reach this question - as I did - then the Beogram Service manual mentions the same bulb part 8230077 as being 12v 83mA.
This is in the the Module 10, Chassis section for Beogram series turntables.
Currently I see the bulb (Beogram 5500) is available from Beoparts-Shop and, presumably, also from Beoparts,
Page 1 of 1 (2 items) | RSS
