Beocenter connection
Mortaime
Posts 6
Mortaime Posted: Sat, Oct 17 2020 12:57 PM
Hi everyone.
I am completely new here - so don’t shoot me, if my questions are in the wrong place
I just bought a Beocenter 1600 with Beovox s35 speakers... and I have no idea how to connect them to the system. Do I need an amplifier or can they be connected directly into the speaker outs?
If you have an answer for me, please address me as someone who knows absolutely nothing in this field. ;-)
Regards Morten, Denmark
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Oct 17 2020 1:13 PM
Welcome.
They connect directly to the speaker outputs.
Mortaime
Posts 6
Mortaime replied on Sat, Oct 17 2020 2:17 PM
Thank you for a quick response
Any chance you can explain how to connect them correctly?
Dillen
Posts 13,191
Dillen replied on Sat, Oct 17 2020 2:51 PM
Left speaker to the left socket (one of the left sockets if your Beocenter has sockets for two pairs of speakers).
Right speaker likewise.
If everything is original and unchanged you cannot do it wrong.
Mortaime
Posts 6
Mortaime replied on Sat, Oct 17 2020 11:20 PM
My center does have outputs for 2 speakers each side.
My speakers wires does not have a plugs - do I just plug in the “naked” (unisollated) wire in the outputs? And what is the small hole by the outputs for? (It kinda has the shape for a flat screwdriver)
Morten
trackbeo
Posts 644
trackbeo replied on Sun, Oct 18 2020 2:28 AM
(Ahh.  They have never seen 2-pin DIN plugs before.)  Here is a link to what you need:
https://soundsheavenly.com/beovox-passive-unpowered-loudspeakers/74-2-pin-din-plugs-sold-as-a-pair.html
Just wire the same speaker terminal (+/-, red/black, whatever) to the same screw/pin in the connector, on both speakers.
Mortaime
Posts 6
Mortaime replied on Sun, Oct 18 2020 2:30 AM
... and by the way - each speaker wire kind of divides into two wires...
Do I connect them together or separately somehow?
Mortaime
Posts 6
Mortaime replied on Sun, Oct 18 2020 2:43 AM
Perfect - the 2 pin din was just the info I needed. I just ordered them online.
Thank you guys for helping a noob out here :-)
trackbeo
Posts 644
trackbeo replied on Sun, Oct 18 2020 2:43 AM
OK, I should have been more specific:
"Just connect each of the two wires with the same speaker terminal (+/-, red/black, whatever) to the same screw/pin in the 2-pin connector, using one connector for each speaker."  (Clear speaker cables will often have one wire silver-colored and the other brass-colored, so you can distinguish them at the other end.  Opaque speaker cables will often have one side of the insulator smooth and the other side with raised lines, dashes, or dots.)
Page 1 of 1 (9 items) | RSS
