I have a BeoMaster 3500 on which the last 4 touch buttons on the right don’t work.I checked them also by detaching the glass, and touching the rubber tips.All buttons work, except the last 4 on the right.
Any suggestion is welcome.
Hi.
Contact "Dillen".
The four rightmost touchpads (7,8,9,st.by) are in the same group = sounds like a strobe problem.Check TR1, TR2, TR3, TR4 and IC1.
Thanks Martin!I have been able to get a defect BM3500 unit, but with working touch panel PCB, including all the 4 pieces of plastic brackets.So I have a working unit now, perfect!
To finish this repair, I need to put in new double sided tape. I have two questions about that:
