Ouverture 4000 Glass Doors Fallen Off - Superglue?!
This post has 2 Replies | 2 Followers
beonewbie84
Posts 6
beonewbie84 Posted: Sun, Oct 18 2020 6:32 PM
So i was lucky enough to find a semi pristine Ouverture 4000 minus the doors which had fallen off but remarkably are in good condition!
Before i get supergluing them back on, am i going wrong?! Is there a better way?
Ravsted
Denmark
Posts 345
Ravsted replied on Sun, Oct 18 2020 6:56 PM
The doors 'click' on ... They are not glued.
There should be two metal clips on each pcs of glass.
They clip into the door-opening-mechanism of the BS 4000
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Oct 19 2020 6:53 AM
The metal brackets fall off the glass. (Or the glass falls off the brackets).
I like to glue the metal back onto the glass using a little Araldite Standard (the blue/white slow setting type).
Page 1 of 1 (3 items) | RSS
