Hi All,
I found this thread and I was wondering because I am running into a similar issue:
Currently I am using a BOSE soundtouch adapter and 2 BeoLab8000's. As it seems the soundtouch adapter is just not giving enough trigger to keep the beolabs running.
Would https://soundsheavenly.com/line-in-connection/singletwin-rca-to-beolab-2-7-10-2500-powered-trigger-kit this solution work in my case as well?
Output Bose: 3.5mm jack
Many thanks in advance and looking forward for your reply,
