Beolink 7000 power supply
Ignacio
Barcelona
Posts 39
Ignacio Posted: Thu, Feb 18 2021 7:29 PM
Hello
I have just got a beolink 7000 with floor stand, unfortunately the power supply is missing so I'm wondering if someone can help me to know which voltage the power supply must be and which pole is the positive and negative, bacause I do not know if it is standard in any other connector.
Thanks a lot
lausvi
Helsinki - Finland
Posts 689
lausvi replied on Fri, Feb 19 2021 9:17 PM
See here: https://archivedforum2.beoworld.org/forums/t/1554.aspx
(It's 9V DC 2A (less would probably suffice). Plug: 5,5mm (outer diameter), 2,1mm (inner diameter), center positive)
Ignacio
Barcelona
Posts 39
Ignacio replied on Sat, Mar 6 2021 8:54 AM
Thank you very much!
Page 1 of 1 (3 items) | RSS
