Beocord 5000 type 4922
112stereo
Posts 3
112stereo Posted: Mon, Jan 20 2020 5:02 PM
Picked this up from a house clearance as a non worker, thought I had better check it out before I switch it on.
As I thought new belts required.
Just fitted new belts after removing the old ones that had turned to mush.
Everything else appears ok with one exception the draw doesn't work automatically,  but works manually !
It runs smoothly and quite freely, there is no power on the motor at any time to suggest it wants to work.
Is there a common fault for this I have a service manual but doesn't rearly tell me anything.
112stereo
Posts 3
112stereo replied on Sun, Oct 25 2020 1:16 PM
Its been a while since i posted this post, has no one got any thoughts shat could be wrong ?
112stereo
Posts 3
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sun, Oct 25 2020 5:02 PM
Did you also replace the belt for the drawer?  Check to see if the motor for the drawer is working. Did you get your belts from Martin?
-sonavor
Page 1 of 1 (4 items) | RSS
