Hi everybody,
I've just bought a beosystem 2500 (without the speakers because I have allready beolabs 6000)
The tape mechanism doesn't work. (I hear the motor spinning when i press tape but nothing happens)
I guess I need a new capstan belt.
Does anybody know when I can get one?
Regards,
Ron.
I think, You can get this belt in any B&O shop or even on Ebay. However first I suggest to check the tape mechanism, because there may be another problem. I had the same sympthom on my BC2500 but it was not the belt.
