Where can I buy a fresh kit of all rubber parts for my Beocenter 2500?
All rubber parts of my Beocenter 2500 are literally chewing gum. Is my fear justified that offers available at ebay may sell parts that are as old as the Beocenter itself? How can I make sure that the parts are fresh and good quality? Any recommendation?
Thanks for any help!
If by "rubber parts" you're meaning the two big transparent sliding squares over the unit, I fear there is no solution.
But if you're talking about belts and so, you should contact our local Rubber Master: Beoworld member Dillen.Plenty of topics on how to change the belts. Don't forget to clean the goo from previous belts.
Good luck
