Chris Townsend:I've lost my Beoplay A2 charger and want to order another one, what size do I need please?
Can you not just use a regular 12v charger? I generally do. With the A1, I use my Macbook charger!
I don't think there is an alternative to the one we order from B&O which is ridiculously expensive. If someone has found a cheaper none B&O version I would be interested to know....
Hi, same question here, lost my Beoplay A2 charger (NOT the USB version). Ordered other 15A/3V charger at webshop, but all the included charging pins do not match the A2 or lead to charging. Anybody got a tip where I can find a charger which works, apart from B&O? Thanks..
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
bramble:Lol...everybody has a "snakes wedding" in a box somewhere....cables cables cables
bramble:And everyone of them is required......somewhere
Is this the one above the right one? Amps not to low? I ordered one on Aliexpress. Should be at least 2.8 A so I ordered 3A. The ones I found one Ebay are less Amps.
Plug is 4.0 x 1.7mm I think. I keep you posted when arrived if it will fit.
B&O Dealer charges € 45,= excluding shipping (also chineese power adaptor). This one € 6,50 including shipping.
https://nl.aliexpress.com/item/32916222763.html?spm=a2g0s.9042311.0.0.4e0b4c4dpdhBVF
or search on
AC/DC Adapter DC 15 V 0.5A 1A 2A 3A AC 100-240V Converter Adapter 15 V Volt 1000MA Charger Power Supply EU US Plug
Seller is Lincoiah Official Store
I have recieved the adapter and it seems to works fine. The only dowside is that they supplied a converter plug to go from the standard plug to the 4.0 x 1.7 mm size. I have asked the store if they could come up with a better solution because the converterplug was not shown on their website when I ordered the adapter.
Duels: bramble: Lol...everybody has a "snakes wedding" in a box somewhere....cables cables cables Ah yes...
Ah yes...
Very recognizable! I even made an excel list of all these connection cables I have with plug type, length etc. to avoid I keep on purchasing new ones haha
