i am planning to bring some B&O touch to my 150 years old,stone made cottage on the island.Living room size 5,5 x 4,5 met,60 cm thick walls.Getting an eye on vintage Beovox S45-2.Also,there is Beovox S4500 type 6318 at local market,app same price,cca 300 €.
Question :what makes difference between S45-2 and S4500,ie.which one is better ?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
They are technically identical.
Dillen: They are technically identical. Martin
Thanks Martin
