Hello,Has anyone here drilled a hole through the wall behind a floorstanding beovision? I am curious about a way to hide cables all together, so Im considering drilling a hole high enough so that the cables cant be seen below the TV. Not sure though if this can be done in a way that looks good from the sides as well is practical. This is in regards to an Eclipse gen 2.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hello,
Another way of hiding cables.
I had an aluminum plate cut at a DIY store and glued two brackets to it.
All cables run in the "sock" which passes behind the plate by a triangular cut at the bottom of the plate.
Then, the cables run through the wall and floor and arrive in a cabinet a the basement level where the other sources are placed.
Regards,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Michael:Hello, Has anyone here drilled a hole through the wall behind a floorstanding beovision? I am curious about a way to hide cables all together, so Im considering drilling a hole high enough so that the cables cant be seen below the TV. Not sure though if this can be done in a way that looks good from the sides as well is practical. This is in regards to an Eclipse gen 2. Beolab 50, Beolab 20, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9i, BeoPlay H6, EarSet 3i, BeoVision Avant 55, BeoPlay V1-40, BeoCom 6000 and so much else :)
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
