Hi, I'm curious about the specs on this speakers drivers. Thinking about replacing if they turn out to be bad. Can anyone point me in the right direction? Pulled the woofers to put on new surrounds. If coil is bad I'll need to replace the driver. If anyone can point me in the right direction it would be much appreciated.
Thanks!
Rob
If you end up in need of replacement drivers, ask at beoparts.com for good used original ones.
Thanks Martin, I'll give them a try.
