Hi all!
I have a Beovision 10-46 TV and recently bought a used floor stand for a Beovision 11-46.
The Beovision 10-46 can be mounted on the floor stand, but the cable is too short and has a different plug. This means that I can't use the motorized stand.
Are you familiar with any connector, which makes the combination of a Beovision 10-46 TV and a Beovision 11-46 floor stand possible?
Thanks in advance!
