Selecting A.OPT and V.OPT?
Lensymphony
Posts 2
Lensymphony Posted: Wed, Nov 28 2012 8:32 PM
Hi there,
I have set up my Masterlink system BS9000,BV5,BL9 but not sure how to select A OPT 0 and V OPT 2?
Is this done with the Beo 4?
Rikard
Sweden
Posts 218
Rikard replied on Wed, Nov 28 2012 9:48 PM
If I remember correctly you press off+list. Then select options, go, A opt and press the number intended. Then do the same with v.opt.
Otherwise: Check the manual for the Beo4, it is in there and the manual you find on this site :)
hotknife
Germany
Posts 840
hotknife replied on Wed, Nov 28 2012 10:04 PM
A OPT O AND V OPT 2  is right if you have plugged your BeoLab into your BeoVision. What Rikard said is right.
LOEWE bild 5.55 OLED + AppleTV; BS4; BL9; BL8000 MKII all black
Page 1 of 1 (3 items) | RSS
