Hi!
I found a good deal on a beosound 8 a couple weeks ago so I went ahead and purchased it.
It works, even though the iPod needs to be wiggled around a bit for the speaker to recognize it because the 30 pin connector is broken at the edge.
Pieces are missing like the wall brackets, the control, the back cover and the aluminum feet. Can someone please guide me to where I can purchase the wall brackets and maybe a 30 pin dock replacement at a reasonable price?
Probably this gets asked in most BS8 threads but have anyone found a 30 pin bluetooth receiver that works with this system?
Thanks!
realeduardog:have anyone found a 30 pin bluetooth receiver that works with this system?
Thanks for the answer trackbeo!
I've tried opening leo's video before but it keeps redirecting me to a "video unavailable" page, maybe he deleted it??
$40 for a pair of aluminum legs sounds pricy, but not crazy. Hopefully the brackets are in the same price range.
Probably my best option is to head to the closest dealer, even though I've been thinking about how to recreate the brackets with something really simple.
I'm going to take my time and document it if i decide to do it myself.
