How to connect Beolab 4000s to a BV7 40 Mk III?
Tony
Chelmsford
Posts 1
Tony Posted: Mon, Dec 21 2020 11:26 PM
Hi Beoworld Members,
I’m new to the forum and can’t find the details to set up my new Beolab 4000 as my rear speakers on my BV7? I have check the details in the BV7 user manual, but this just references another guide which I can’t find.
I’ve connected socket 1 of the left beolab 4000 speaker cable to powerlink socket 1 (sub) on the BV 7 and daisy chained (socket 2) the other speaker cable to right speaker (socket 1)
i’ve configured the beolab 4000s under the speaker types menu, and when I scroll down in the menu the beolab 4000 led changes to green and I can hear the white noise test signal in each speaker as I scroll
I think issue might be due to the sound system setting currently showing output format: stereo Speaker 1.
i believe I need to change a menu to set up speaker 2 and 3 to complete the connection or is there something else I’ve missed?
can anyone help and show where I’m going wrong?
Many Thanks and looking forward to your support.
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Dec 22 2020 8:10 AM
Merry Christmas.
Razlaw
Posts 4,345
Razlaw replied on Tue, Dec 22 2020 7:27 PM
Don’t connect them to the sub connection, use one of the others.
Razlaw
Posts 4,345
Razlaw replied on Tue, Dec 22 2020 7:28 PM
Also, have you set the switches in the 4000s to left snd right?
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
