BeoLab 3 main power supply PCB broken. Any ideas?
This post has 0 Replies | 0 Followers
prorsum
Posts 6
prorsum Posted: Tue, Dec 22 2020 4:37 PM
Hello,
finally got myself a pair of BeoLab 3, but as it turns out, on one of them the main power supply is damaged (fuse, 2 SMD capacitors, a rectifier and the small transformator).
So I found another one which I then wanted to use for spares.
But luck wasn’t on my side. Same issue.
Does anyone know about the specifications, especially the transformator. The other parts should be fairly easy to get.
Or is anyone selling a MK I power supply?
Thanks in advance
Page 1 of 1 (1 items) | RSS
DigiCert Secured Site Seal
