Hello,
When using Beosound A1 2nd Gen the Windows volume is limited at 69%.
Even if I'll try to increase the volume in Windows by more than 69%, the value in increasing but immediately after that is going automatically to 69%.
The A1 is new, the battery is 100% and the firmware is latest 5.2.7.
Is there anything I can do to allow a volume more than 69%?
I mention that in the Android app there is no Default and Max volume setting like it is for other Beoplay speakers.
Thank you
Virgil
