Merry Christmas to all!
https://www.qobuz.com/fr-fr/info/Hi-Fi/Actualites/Notre-selection-des-meilleurs183841
Google Translation:
"The Bang & Olufsen Beosound Stage soundbar is the pleasant surprise of this year. This type of audio device is mainly oriented towards the reproduction of Dolby and DTS soundtracks. Sound reproduction follows an orientation that is not always compatible with listening to music. Thanks to the Stage, B&O has created a dual function bar, comfortable for movies as well as music.
This soundbar controls low frequencies, which allows it to do without a subwoofer. Attached to the wall (the positioning we recommend), it replaces a pair of small bookshelf speakers - and that is its strength. The signature is warm by default, but the many settings from the app make it easy to adapt the sound to your tastes. This bar is the best Hi-Fi and home cinema compromise that we know."
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
