I thoroughly doubt something is in the works.
However, it may be that the iOS apps work on the new (M1) Apple silicon Macs.
I dont have one yet, but as soon as I do I will come back with some feedback.
For context (for those perhaps unaware), the new Macs can run iOS apps, unless the app provider opts out.
OlivierC:Hello, Reading from other threads it looks like there’s still some work to do on the iOS / Android B&O app but I was wondering if there’s anyone else out there who’s in the same user case I am. During these sad times we live in, made of home working and lockdowns, I find myself using my Mac while the BV is running. It would be convenient to control it (and other B&O products in the same network) with the same device I’m using, without the need to reach a remote, a smartphone or a tablet. So what about having something like the B&O App we have for the mobile devices, same functionalities, but for macOS / Windows computers? Does anyone know if there’s something like this on the works? Thank you and I wish you all the best possible Christmas and New Year. Olivier
Olivier
OlivierC:So what about having something like the B&O App we have for the mobile devices, same functionalities, but for macOS / Windows computers?
Beoliving & B&o app both run on a Mac Mini with Apple's M1 processor. Both with complete functionality
Windows 10 can emulate Android (apps) with some Samsung phones (beta). I have no knowledge about the Android B&o capabilities in Windows 10 though.
Yes, that would be great. I wrote a small macOS app as a proof-of-concept to be able to remote control using the play/pause and vol-up/down keys from my mac computers: https://github.com/tlk/beoplay-macos-remote-gui
Would much prefer officially supported tools made by B&O, of course.
OlivierC:Too bad I am still in the Intel realm (I presume there are still many) and I’m using my laptop for easy tasks, it might take some time before I will upgrade to a Mac equipped with the Apple CPU
Carolpa:Use TLK's tool. It works real good on the Intel Apples.
Hi Olivier,
Yes Xcode is quite massive, last time I deleted a version it was going through maybe 300-400.000 files :-)
I have made a new release available that does not require Xcode:
This has been built on the Github infrastructure operated by Microsoft but macOS defaults to preventing you from running the app. Please see the link that describes how to open a Mac app from an unidentified developer.
Hope this helps!
Best regards,
Thomas
It could be that the BeoplayRemote.app does not (yet) work properly with BeoPlay-V1 devices. Sorry, I did not check that earlier. Have you been able to remote control the BeoPlay-V1 with the official iOS app when the BeoPlay-V1 and your mobile are connected to the same WiFi network (not hotspot)?
I found a discussion in the Home Assistant community about remote controlling a BeoPlay-V1. There is a user reporting that volume control works from the Home Assistant software, so it should be possible to make the BeoplayRemote.app work as well.
If there is a network expert out there with a BeoPlay-V1 and an iOS device, pcap-records of interaction between the official iOS app and a BeoPlay-V1 device would be well received :-)
Best regards, Thomas
