Hi
Does 75" Avant MK1 have two-way communication with the remote control? If so, how do I enable it?
How do I rename or delete presets on the positions of the motorized stand? Right now I have three fixed default positions which are called Standby, Video and Audio. How do I make it to be Standby, Dinner tabel and Couch?
Is it true that these displays have big trouble showing the right color on the middle of the panel which is mainly grey and blue colors, or do I have a bad TV set?
Examples here: Backlightbleed
no these tv do not have 2way comunication, about the stand, stby,audio,video is fixed but you can have six more in stand settings meny on tv
How do I set a default position for the stand when i turn it on?
Ouch, that backlight bleed is the horror! This can not be normal right?
Those white strips in your first image are maybe even worse.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
I don’t think the white lines are a problem; this is probably just the source. It’s difficult to comment on light bleed too as we don’t know what you were viewing (or supposed to be viewing) with the screenshot you took. The second picture looks fine and normal, at least to my eyes.
More info is needed. Light bleed is common on these TVs as they are edge lit so light bleed would usually show up more along the sides than the middle, the latter of which is just part and parcel of owning an LCD television, which is not a perfected technology. This is where OLED comes into its own as each pixel is individually lit.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Thank you for your answer :)
I'm not complaining about the white lines, but instead the massive backlight bleeding at bottom center at the display. The color should be uniform at the bottom center part of the screen on both pictures but it is not. The backlight bleed gets even worse when we watch a dark movie, because of this huge grey blop at the middle of the screen.
I do have another 75" LCD tv set at home, and it doesn’t have this backbleed at the middle of the screen at all when using the same source : Apple TV 4K. It does have minor backlight bleedings a few small places, but that is what to expect of an edge lid panel I've been told.
