Hi - I have inherited a BeoVision 7 (9334) with an electronic stand and a Beo 4 remote. I have managed to get the master code for the TV so it's working, but don't seem to be able to figure out how to move the stand.
The stand 'socket' on the TV is empty, but there is a cable called a 'Powerlink' going from the TV to the stand - does that do the same job, as there doesn't seem to be anywhere in the stand to plug another cable in? and if so, how do I get the stand to move, using the remote control please?
Apologies for all the questions, and thank you in advance.
Hi, so there should be a cable plugged into the 'Stand' socket on the connection panel on the back of the television.Once you have this plugged in, press the 'List' button on the remote control until you see 'Stand' then press 'Go', from there you can use the left and right arrows to control the stand.
