Beoremote one BT and two audio source
This post has 1 Reply | 0 Followers
Erik-nl
Posts 41
Erik-nl Posted: Sun, Jan 17 2021 3:47 PM
It is possible to use a Beoremote One with 2 audio sources (e.g core & M5).
Or does one need 2 remotes?
crossbytje
Posts 224
It needs to be a Bluetooth version of the BeoRemote One (BT), but then yes, you can use 1 remote with several devices.
In the list menu of the remote, you can select which device to control. It is not possible to control both simultaneously, you need to switch between devices in the remote.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Page 1 of 1 (2 items) | RSS
