Hi
I have a new eclpise v2 which has just been replaced as the first one had connection problems.
l am trying to get my Beomaster 5 to play over the connected speakers , I also have a NL/ml convertor which is like double Dutch to me .
I have had some help of members but still can not get it working ? So fare the remote is working the Beomaster 5 but there is not connection to the tv I have tried the join button? But nothing is happening
help please
stuart50_1:Hi I have a new eclpise v2 which has just been replaced as the first one had connection problems. l am trying to get my Beomaster 5 to play over the connected speakers , I also have a NL/ml convertor which is like double Dutch to me . I have had some help of members but still can not get it working ? So fare the remote is working the Beomaster 5 but there is not connection to the tv I have tried the join button? But nothing is happening help please
Call it a Beosound 5 if you have and the Beomaster 5 and the Beosound 5, otherwise you set others in the wrong direction.
You stopped discussing, so the issue never ended!
Please try to post pictures of the BLC settings. Say something about how you have connected everything. Tell about the settings of the BS5 (option, AM setting, which remote button started the music ); option setting of the Eclipse
do you make a picture with your (i)Phone? Or do you make a screenshot on your PC/Mac? Try to have JPC or PNG file formats.
then you should upload them to your account in the Beoworld server.
posting this picture use the film strip icon above (visible when writing a post)
https://imgur.com/a/ORaomp1
Hi please have a look at the link as I can not post images on the web site ?
I have the Beosond5 set as AM and NMusic and NRadio.
I am nott sure what setting to look for on the eclipse.
Thanks agin for having a look at this , the tv was changed that is why I stopped the conversation .
stuart50_1:https://imgur.com/a/ORaomp1 Hi please have a look at the link as I can not post images on the web site ? I have the Beosond5 set as AM and NMusic and NRadio. I am nott sure what setting to look for on the eclipse. Thanks agin for having a look at this , the tv was changed that is why I stopped the conversation .
The other thing, in the other post you repeatingly talked about "CD"? Could you elaborate? In your previous setup did you start the music with CD or N.Music?
Hi I think the setting is in Roles you can call nmusic CD and so on
The
Beosound 5 does react to the BT1 so the chances , made it so the one remote works both tv and Beosound 5
I guess the speakers are connected to the TV? Try changing Networklink -> Connect to Primary to your Beovision Eclipse (I would also change secondary to the TV). This way your TV should turn on and play music when you press CD. Else the setup looks good to me.
Can you give clearer instructions please
Hi Everybody it’s know working fine
Thanks for all the help
I now have to look at getting rid of a hissing from my Beolab 20 they have correct cable as I bought these from Sounds Heavenly
