5500 CD sporadic ops
This post has 1 Reply | 2 Followers
Edgy01
Posts 17
Edgy01 Posted: Sun, Dec 27 2020 3:27 AM
My BEOGRAM CD 5500 usually loads a CD quickly and then you see the number of tracks and then know that all is well. After awhile, that same CD will Los but not be discovered by the CD 5500 at all. The CD spins a bunch but then you can tell there is no communication—the number of tracks doesn’t pop up.
Sometimes when you get a successful ‘load’ the first track sounds all scratchy, yet the CD is pristine. Dirty laser pickup?
It’s very frustrating!
Regards,
Dan
Left coast
Menahem Yachad
Jerusalem, Israel
Posts 1,249
This is a standard Philips CDM4 TDA1541 deck, and labeled B&O on the outside.
Therefore all the standard Philips faults apply to your machine.
Check this as a start
https://archivedforum2.beoworld.org/forums/t/29278.aspx
Page 1 of 1 (2 items) | RSS
