Hi
Just joined so hopefully I am doing this right in the right place!
I have a Beocenter 2200 and the display lights have stopped working.
I would welcome help in how to get inside to replace these,as I cannot find a video for this anywhere.
Also how to source the replacements.
Chris P
Pull off the volume button.Open the turntable dustcover.Push in the small dimple in the hole at the vertical side to the right of the turntable while pushing down a little on thevent grill and pushing the dial cover forward.Takes a little practice.The dial is then held by two small clips.Take it off and you will have access to the lamps. The lamps are soldered in.
Lamps here:https://www.beoparts-shop.com/product/lamp-set-for-dial-illumination-beocenter-2100-2200-4000/
Ignore email that I might have sent to you via the system! This works in Adobe forum but not sure about here. It hasn't gone into the thread
Thanks for info. Found Dimple and vent grill but not sure about " pulling off volume control"
This is slider below lip where the buttons are. There is also the tuner edge thumb wheel there.
Does the slider pull off. Don't want to break anything!! And is the tuner control left in place?
Chris
The volume knob pulls off.See here:https://beoparts.com/2016/11/06/beocenter-2100-2200-4000-volume-slider-button-2775956/
The other buttons you can leave alone.
