I have connected my Beomaster 5500 with a DIN cable in TAPE2/AUX to the T1611 converter and then the master link cable to my beovision 10 and then the 2 beolab’s 6000 in the beovision. This works perfect music and sounds great.
Only 2 issues.
1: I first have to put on my tv (DTV, or something) to put on the radio. I can’t just press in the radio button on my beo4 remote or master control panel. After i put on the radio the tv goes on black screen, witch is good. But i would like to have it directly with the radio button.
2: I can not change the volume with the master control panel only with the beo4 remote. (I only can use this when i am using my headphone). Maby because it can not communicate with the beovision 10.
Hopefully can someone help me fix this ‘problem’s’, if its even possible.
James
You probably need to have different options settings set.
You will find more info and how to do it at the link below
https://www.beoworld.org/beotech/index.htm
Link >>>>
Thanks, i will take a look.
problem 1 fixt itself. Don’t know how but it works now. :-)
