Preamp for Beolab
Silou
Switzerland
Posts 465
Silou Posted: Thu, Jan 21 2021 7:48 PM
Which brand does a preamplifier or better A/V preamp with trigger output for connecting Beolab ?
Carsten
Copenhagen, Denmark
Posts 44
Carsten replied on Thu, Jan 21 2021 8:28 PM
Try to look at Yamaha WXC-50.
Silou
Switzerland
Posts 465
Silou replied on Sat, Jan 23 2021 9:08 AM
Carsten:
Fine good idea for audio.
And any idea for AV ?
crossbytje
Posts 224
I'm using a Marantz AVR with preouts. It has a 12V trigger, but you can find cables with integrated downgrade to 5V trigger signal for BeoLabs.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Ravsted
Denmark
Posts 345
Ravsted replied on Sat, Jan 23 2021 2:02 PM
I did it this way.
https://archivedforum2.beoworld.org/forums/t/45510.aspx
Guess there are many receivers like the Harman Kardon with a 230v socket turning on/off with the amp. Simply plug in a good quality usb charger and you'll have a 5V trigger.
Silou
Switzerland
Posts 465
Silou replied on Sat, Jan 23 2021 2:25 PM
Thanks for your input !
If found this thread:
https://archivedforum2.beoworld.org/forums/p/42873/311423.aspx
about Canton Smart Connect 5.1! It seems a very good products ! Need to DIY to get trigger output.
Page 1 of 1 (6 items) | RSS
