Hello,
I am in need of replacing the idler wheel and bushings for my turntable.
I would appreciate assistance with information of parts supplier in the USA.
I live in the San Diego Area.
Thank You,
Art
Hi Art,
Google beoparts-shop.com-they have a large range of parts. If no luck there, you might try and contact Martin ( username Dillen) on the Beoworld site.
regards
Noel.
Thank you for your fast response.
I have been searching around and parts are very difficult to find.
The basics are around but specific parts like idler wheels are scarce.
I sincerely Appreciate your response.
Hello again Art,
I would strongly recommend you contact(username Dillen ) Martin on this site.
From what I've seen,he is an expert on fixing most problems B&O, but I think he also has a lot of spares/replacement parts stashed in his dungeon !!
If he can't help you,maybe he can point you in the right direction.
